Can anyone help me with the circuit pls (ECG circuit)
BlackCat123
Joined Mar 14, 2023
19
Does anyone know any engineer that can help troubleshoot the initial checking will be done on March 17 morning. We are willing to pay. If possible, in person, if not, it's still ok.
BlackCat123
Joined Mar 14, 2023
19
here is an example of virtual ground circuit.
it is just a pair of resistors and capacitors.
one side connects to large supply.
the other side is 3-terminal substitute for split power supply
what is that next to the resistors?
I did like that but when I connect to the Vcc and Vee, for example I adjust voltage of the power supply is 10V. When I connect to Vcc, it stops to around 1.8V while Vee is 8.2V. Can you fix this for me?
DickCappels
Joined Aug 21, 2008
10,661
Looking at your breadboard I don't see any power supply decoupling capacitors. Adding capacitors in accordance with the datasheet recommendations is a good practice and may save you a lot of time and trouble tracking down performance problems.
BlackCat123
Joined Mar 14, 2023
19
you mean the bypass capacitor?
Audioguru again
Joined Oct 21, 2019
6,826
Most old opamps work perfectly when powered from two NEW 9V batteries instead of +15V and -15V. You measured different battery voltages then maybe one battery is old and needs to be replaced?
