Can anyone explain to me how this current-voltage converter work?
thanhvu94
Joined Oct 1, 2016
8
Hello everyone,
I'm working on a project with a sensor which has an analog circuit to convert output current signal of photodiode to voltage like attached in the file. I'm not so specialized in analog circuit but I really want to understand how this circuit can convert from current to voltage. Can you explain in detail how does it work (the sub-component linear amplifier and non-inverter amplifier)?
Here is the only information written in the report about this circuit but I can't understand well:
- The linear amplifier part is an analog low-pass filter with a cutoff frequency equal to 106kHz. Considering the high gain given by the resistance of 150kOhm, the linear amplifier aims at preventing signal from oscillations.
Thank you for your explanation.
P/S I also attach the paper of the sensor.
ericgibbs
Joined Jan 29, 2010
21,567
hi,
It amplifies the low level signal output from the Trans/amp, by a factor of 1+ (100k/4k7)= ~ 22 times.
The non inverting mode means that the output signal from the trans/amp is not inverted
E
AnalogKid
Joined Aug 1, 2013
12,266
Simply DC gain.
Both amplifiers are linear. The first is a "current-to-voltage" converter, where 1 uA of photodiode current produces an output of 0.15 V. The second is a DC coupled gain stage with a gain of 22.3. These values are based on my guess of the resistor values in the schematic. If there are decimal points in the resistor values, I can't see them.
ak
