can anyone explain the role resistor in this schematic
ansh314
Joined Jan 22, 2021
hello everyone,
I want to create a radio transmitter circuit and understand how it works but cannot find the role of resistor 330R and capacitor 4p7 in the schematic.
thanks in advance.
ansh314
Joined Jan 22, 2021
Those are critical. They create the feedback that makes the circuit oscillate. If you understand the circuit, why did you think it oscillated?
Bob
i think 330R is used to resist the maximum current flow in the circuit. but still got no idea about working of about 4p7
Audioguru again
Joined Oct 21, 2019
6,826
The transistor operates as a common-base amplifier for the RF. Its RF input is at the emitter that cannot be shorted to ground.
The 4.7pF capacitor provides positive RF feedback from the collector to the emitter so that it oscillates.
Its simplicity causes problems;
Since the capacitance of the transistor changes as the battery voltage runs down then the RF frequency will also change.
Since the tuned circuit is at the antenna then the RF frequency will also change if something moves towards or away from the antenna.
Since the output level from the microphone is very low it needs a mic preamp or the received sound produced from an FM radio will also be very low.
Since all FM radio stations produce pre-emphasis (treble boost) and all FM radios produce matching de-emphasis (treble cut) then the received sounds will be muffled with high frequency sounds reduced.
Audioguru again
Joined Oct 21, 2019
6,826
Everybody who complained that this circuit does not work built it with a messy tangle of long wires on a breadboard. They did not know that each wire has inductance and capacitance to other wires and the rows of contacts on the breadboard also have inductance and capacitance between them and to the wires.
I built mine compactly soldered on a stripboard with all the problems I mentioned fixed, and it works perfectly:
Delta Prime
Joined Nov 15, 2019
1,311
Hello there
:) Echoing my superiors.
The 4p7 capacitor across the transistor serves to keep the tank circuit vibrating. In theory, as long as there is a supply voltage across the parallel inductor and variable capacitor, it should vibrate at the resonant frequency indefinitely. In reality however, the frequency decays due to heating losses. 4p7 is used to prevent decay.:)
