Can anyone please explain the difference between DC bias field versus AC bias field ?
nckt
Joined Oct 25, 2021
What is DC and AC bias? Are these two applied together to a circuit ? Also what is DC bias field ?
Papabravo
Joined Feb 24, 2006
22,111
I've never heard of a DC bias field. Can you provide some context?
A circuit can be subjected to two different types of analysis. A DC analysis is where each point in a circuit has a defined and constant DC value This analysis establishes the DC operating point. A constant DC value in between a power supply value and ground is referred to as a DC bias (value). It is often constructed with a pair of resistors called a voltage divider. Once the DC operating point is established then a small signal AC analysis can be performed by looking at small signal deviations from the DC operating point.
I don't know that the term AC bias has any useful interpretation. If it does it's above my pay grade.
nckt
Joined Oct 25, 2021
It would help if you told us the context to which this is applied.
Hi MrChips, I first came across the DC bias field reading a research paper. The text contained :
The photoconductive antenna consists of a DC biased metal dipole antenna patterned on a photoconductive substrate. The optical pulse is incident on the antenna gap (G), propagates into the photoconductor, and begins to generate photocarriers inside the photoconductor. The generated photocarriers are accelerated in the DC bias field, producing a transient photocurrent, which drives the dipole antenna.
I would have thought it is just the usual electric field as a result of DC bias. But I am not 100% sure.
Once I agonised over DC bias, I started thinking about AC bias and came across a "tape recording wiki article" shared by @AlbertHall. Now I am even more confused about the output and application of these two.
nckt
Joined Oct 25, 2021
The context for the DC bias field is from a research paper that mentioned the following :
I thought it is just a normal electric field but not sure! Like eg AC bias, I didn't realise it is used for tape recording until I pondered on the term "bias".
35,176
According to the paper, there is no AC bias field involved.
Hence a DC bias field refers to a constant voltage applied between two conducting material separated by an insulating material.
28,258
Everybody: go back and read post #7! It sounds a whole lot like the desription of a high speed photodiode being driven by a light source to create an RF signal fed to an antenna. An interesting way to avoid transmission line losses. but not likely to produce a whole lot of power.
