Calculations and substitutions to derive a formula
kalemaxon89
Joined Oct 12, 2022
389
I am not able to derive this formula:
starting from this data:
1684958669767.png I re-write the first formula better because it reads poorly: Irr = (dir/dt)*t4
They are probably simple mathematical calculations where you add subtract the same sum until you find the result but I am finding difficulty.
WBahn
Joined Mar 31, 2012
33,169
I'm having a hard time deciphering your writing, but if there really are t4's and t5's in there, then I think I've got it.
It's just a couple lines of algebra.
Start with what you want -- t_rr. You have two options: Start with the second equation, which already has t_rr on the left, or solve the third equation for t_rr. Either will work, but the first seems more direct.
Write t5 in terms of S and t4.
Then write t4 in terms of what is in the first equation.
Then get rid of I_rr based on the third equation.
Now solve this for t_rr.
kalemaxon89
Joined Oct 12, 2022
389
Thank you! I followed your steps and found the final formula.
Can you help me find this formula as well:
Irr = sqrt{ 2*Qrr*dir/dt / (S+1) }
I'm trying to derive it directly from trr =sqrt(..) that we just found, is that the easiest approach?
