EMI filter formula and calculations
andrew74
Joined Jul 25, 2022
273
Some time ago, I noted down this example of an EMI filter in my notes.
Unfortunately, I cannot remember which paper I took it from.
The paper began with these two requirements:
- Set an attenuation greater than 10dB at frequencies [10k .. 150kHz]
- Set an attenuation greater than 20dB at frequencies [150k .. 30MHz]
Let's focus on the last sentence of the second image:
"Imposing the two frequencies, we can calculate the elements of the filter in Figure 4"
If I understand correctly (English not being my native language), the author set the two frequencies f_rcm and f_rdm in the formula, then did some calculations to find the values of Cx, Cy and Ld that you see in the first photo.
So, to summarise, the requirements (in theory) should be satisfied with the following values:
Lc = 2.4mH
Cy = 3300pF
Ld = 180uH
Cdm = 0.47uH (I think he means Cx (?))
(values shown in the first photo, I have only reproduced them here)
The problem is that when I substitute these values into the formulas, I get:
f_rcm = 40kHz
f_rdm = 12kHz
(..I did not consider Closs in the formula!)
How did the author manage to satisfy the requirements?
..40kHz and 12kHz do not seem very similar to the requirements to me.
Correct me if I'm wrong, but the only thing that comes to mind is that those calculated frequencies are cut-off frequencies, so they have 3dB attenuation... perhaps by plotting the Bode diagram with LTSpice, it might turns out that the two requirements (10dB and 20dB attenuation) are actually satisfied.
MrAl
Joined Jun 17, 2014
13,852
Lc = 2.4mH
Cy = 3300pF
Ld = 180uH
f_rcm = 40kHz
f_rdm = 12kHz
I did not realize that 33-mousepointer-pf was a value for a capacitor (Cy1). Must be a new type.
I had to look at that three times I thought my eyes were going buggy.
MrAl
Joined Jun 17, 2014
13,852
Lc = 2.4mH
Cy = 3300pF
Ld = 180uH
f_rcm = 40kHz
f_rdm = 12kHz
Are you asking for an analysis of the filter you have shown in your first post?
AC analysis is fairly straight forward, it's just an extension of DC static analysis. The only tricky part is the common mode choke, for which you have to know how mutual inductances works, although there may be a chance of not having to include that in the analysis.
If anyone quotes a frequency it's usually the -3db point frequency. But if someone quotes a frequency AND a given attenuation, then you have to consider that attenuation at the frequency where you get that level of attenuation. If one quote is for -10db, then you have to find the frequency that causes a 10db cut, not a 3db cut.
