Burnt transistor
Santhosh@123
Joined Sep 13, 2020
I have washing machine pcb and its water inlet valve is continuously on when i checked pcb one transistor was burnt how to the transistor no and valve voltage is 230 volts check the photo attached ( some digits are visible like
Ramussons
Joined May 3, 2013
1,572
Which component is burnt? How do you know "it" is burnt?
The bolted Component is likely to be a Triac as Dodgydave mentioned, the other may be a transistor or a Diac .....
