- Joined Jan 23, 2018
- 28,605
My experience with misfiring spark plugs has been mostly that they present a lower resistance so that there is not enough voltage developed to produce an adequate spark. So my first spark plug check is done with an OHM METER, without even removing the plug from the engine. A simple and easy test.Yes, thanks for stating that, I wonder what exactly can be measured that lets us detect a difference between a working and a failed or failing, spark plug.
I'd imagine knowing the voltage that is necessary to make it spark would be helpful as well as any leakage/resistance as that voltage rises.
