Hi All,
I'm attempting to restore a Camaro from the 80's that uses pcb's to control the lighting for the car. The retro "light module pcb" is discontinued, and finding used ones that work is difficult. The most common problem is that over time the electronic components wear out and when the headlights are activated the lights flash on and off repeatedly... pretty annoying when trying to drive at night.
The module functions as follows:
When the driver presses the headlight "on" button a ground signal is sent to the solid state (light control module) that then energizes the relays for the headlights.
Most automotive headlight switches are mechanical and simply complete the ground for the headlight circuit. My switch is not mechanical and relies on the programmed instructions on the pcb to then activate my headlights.
I could bypass my module to get the headlights to activate but it would require me to use a mechanical switch. I would like to keep my stock switches that simply send a ground signal when pressed.
So here is my question:
Is there a way to build a simple circuit that when sensing a ground input, energizes a relay and keeps the relay energized until another input directs it to de-energize?
If it is possible to do this, what would be the easiest way to create this?
Best,
Alex
Best,
Alex
