building 16-Nibble RAM implementing 2 functions: read and write
hyunjoonii
Joined Oct 10, 2020
How do i make this circuit with logism?
i have to build it only with OR,AND,NOT,XOR,XNOR,D-flipflops
part 1. making 4 bit register using flip flops: circuit should perform read and write in one clock cycle:
when enabled: read_write = 1, En = 1,
and data will be saved in flip-flops.
value appear in Nib_Out within one clock cycle
if En = 0, no write operation ==> last value of nibble should be represented as Nib_Out
when read_write = 0, value should be observed on the Nib_out regardless of what En is.
part 2. building 16-nibble RAM:
using the register from part 1, add additional circuit to implement this...
1. circuit perform read and write in one clock cycle: to read from RAM (read_write = 0), with next clock tick, value of nibble that address bits indicate should be in Ram_Out
2. RAM circuit should read 4-bit piece of data as input and set this as value of nibble
if Data = 1000, Address = 0011, in the next clock cycle the value of 4th nibble should become 1000 and value should be displayed on output
3. entire circuit should have just one single clock signal
KeithWalker
Joined Jul 10, 2017
3,615
We are not a free electronic design service, and we do not volunteer to do people's homework. If you show us your best efforts and let us know what problems you have run into, we will try to help you.
