- Joined Jan 23, 2018
- 28,013
Once again, I have never seen the TS drawing of the circuit being built, I have only seen what I find at the end of a link.
So I have no way to verify that a circuit on a PCB is the same.
Next, I have no way of looking at an actual PCB and seeing if the conductors are adequately sized.
I have not seen the circuit with the voltages relative to the supply terminal negative shown. AND I still have no clue about the values of those resistors. And my ability to see what other folks are thinking inside their heads is worse than poor!
Next, consider the possibility that in copying the drawing shown in that link, that an error happened. And has been duplicated several times! And consider that some voltages on the version that works are not the same as on the versions that fail to function correctly. How can I know that???
