Buffer with pot
Tony Elliott
Joined May 8, 2015
160
Hello, I have one opamp only to use with this potentiometer. Which one would you choose first or second schematic?
I have tested both ways and can’t see a difference but from your experiences I am curious.E8607E57-42E5-4F11-BE55-8B62E86A947E.jpeg
BobTPH
Joined Jun 5, 2013
11,631
The first gives you lower output impedance, the second gives you higher input impedance. Which is more important for your application? In other words, why dod you need a buffer in the first place?
Bob
Tony Elliott
Joined May 8, 2015
160
Bob
I need this attenuated signal to keep its shape. For example: even at half or quarter in amplitude the signal needs to stay strong and clear.
Ya’akov
Joined Jan 27, 2019
10,288
At this point it would help to know what this is being used in. What does the input come from and where does the output go?
