Buck converters and remote sensing
engr_david_ee
Joined Mar 10, 2023
364
What you showed was the output circuit of a buck converter. It lacks all the control circuitry.
It could be driven by a fixed PWM signal, and then it would be an unregulated buck converter. I.e. the output voltage would vary with the input voltage and load. If that is what you want, there is no sensing of the output, remote or not.
To make it a buck regulator, it needs a much more complex circuit as others have pointed out.
Thanks for the explaination and describing the un-regulated (PWM from MCU driving the switching transistor) and regulated buck converter.
My questions in this thread is about the circuit of regulated buck converter in which we can attach sense wires we well.
