I don't have any specs of the motor, I just place a resistor, not really meaning the true loadPlease post the motor's datasheet as well, if available. I doubt it has a series resistance of 1k, as you previously posted.
Ok ... what are the motor's physical dimensions? can you post a pic?I don't have any specs of the motor, I just place a resistor, not really meaning the true load
The how can you know that the 2N2222 transistor can drive it?I don't have any specs of the motor, I just place a resistor, not really meaning the true load
I measure the current and is less than 200mA, I guess the 2N2222 can handle up to 800mA according to the specThe how can you know that the 2N2222 transistor can drive it?
That is choose as 2SC1384(1A) is better, for the power dissipation, you should choose a rating Ic is three times or more of calculation (or measuring) values.I measure the current and is less than 200mA, I guess the 2N2222 can handle up to 800mA according to the spec
Yes, that should be okay.I measure the current and is less than 200mA, I guess the 2N2222 can handle up to 800mA according to the spec
I know that is a normal dc motor because I add the encoder to it, it's a magnetic quadrature encoder 40pprToo many wires in that motor... if I didn't know better, I'd say it's a brushless.
That is using as 2SC1384(1A) is better, choosing a rating Ic values for three times or more of calculation or measuring values is good for power dissipation.I measure the current and is less than 200mA, I guess the 2N2222 can handle up to 800mA according to the spec
When you in series with two supercapacitors then you should in parallel with a balancing resistor (Please see the section -- Why do ultracapacitors require balancing? What are the balancing methods?) for each supercapacitor, the R values is :I have two 2.7v 10F supercaps in series
It's not, unless the circuit is wired differently than the schematic.Any idea why the diode is letting the voltage pass to the regulator side?
I didn't know that, thanks for the tipThat is using as 2SC1384(1A) is better, choosing a rating Ic values for three times or more of calculation or measuring values is good for power dissipation.
R = (Vcc/2)/I
= 2.5V/114 μA
= 21.923K
You can choose two 20K.
I will re-wire again the circuit, maybe I did something wrong, thanks for all your help guys, I learned a lotIt's not, unless the circuit is wired differently than the schematic.
I think the capacitor discharge is through the transistor resistors and the lack of a resistor on the MAX809 output as I previously stated.
