Hi, I'm designing a PCB to control a motor and a couple of accessories, it has a main power supply of 13.4v but I will never know the polarity of the voltage, so I'm using a diode bridge as a polarity correction, the controller is an arduino (5v) so I'm using a buck converter to convert to 12v to 5v.
It has two main requirements:
1. needs to be a very small layout
2. needs a uninterruptible power suppl y
because is a small layout I want to use a super capacitor as a UPS, it gives me enough power to keep the controller on (I don't care about the motor) when the main power is disconnected (that is not more than a couple of seconds) the problem is that the current is flowing to the motor discharging pretty quick the capacitor and I'm afraid of damaging the buck converter due that is working backwards, I tried with a schottky diode between the buck converter and the capacitor (not a problem having ~4.8v) but apparently it doesn't work, when I disconnect the 13.4v PSU I can read voltage coming from the capacitor in the other side of the buck converter and can see it dropping very quick
If Somebody can explain me what I'm doing wrong or a better solution I will really appreciate it, Thanks
Extra points: I'm using a MAX809 as a voltage monitor, when the voltage drops to less than 4v I want to shutdown the whole system, I read that I can do it with MOSFETs but I have never use a MOSFET before and I'm afraid of not feeding enough voltage or current to the control circuit
