Buck-boost DC-DC converter
Ali Doğan Sönmez
Joined May 7, 2019
Hi everyone, I want to design two stages interleaved in a buck boost converter. How does it effect the design? I didn't find anything about it. Can you help me?
LowQCab
Joined Nov 6, 2012
5,101
It's been standard practice on Computer Mother-Boards for Decades.
It's called a "Multi-Phase" Buck, or Buck-Boost, SMPS.
I'm not particularly familiar with them, but I think most of them are running 6-Phases.
The advantages are, smaller Output-Filter Components, and incredibly FAST Transient-Response.
There are plenty of Controller-Chips available to create your own version,
that is, if you can deal with SMD Construction.
Ali Doğan Sönmez
Joined May 7, 2019
ı Don't know bcs They gave me a task to design Two stages interleaved buck boost dc dc converter. Still I'm researching. But I didn't decide how it should be a two stage. I think multiphase is difference than two stage.
LowQCab
Joined Nov 6, 2012
5,101
Your Instructor is trying to get you to figure-out how this could be done.
Most SMPS Chips can be set-up to be a "Master", or a "Slave".
Read several Data-Sheets for various SMPS Chips, and see if you can design a solution.
With 2-Chips, with Clocks running at 180-degrees apart, you will have a "Two-Stage" SMPS.
Each Chip must have all of its own components, except for the final Filter-Capacitor, which can be shared.
Ali Doğan Sönmez
Joined May 7, 2019
Thanks for your effort. Now It have shaping more in my brain.
BobTPH
Joined Jun 5, 2013
11,516
Two stage says to me, a buck stage and a boost stage in series, which is one way to get buck-boost. The common single stage buck boost give a negative voltage output, which may not be desirable.
Bob
Ali Doğan Sönmez
Joined May 7, 2019
Bob
You mean that stages connected each other with cascade connection right ? Is it possible ?
