BTUs you need for a given area.
biferi
Joined Apr 14, 2017
541
I had notes on the Math you use to find how many BTUs you need for a given area.
Square Footage in Feet X
I do not have the other part of the Formula.
What do you Times the Square Footage by to find the BTUs you need for an area?
I live in the USA.
BobTPH
Joined Jun 5, 2013
11,662
There are so many other factors, one more cannot possibly give a very accurate result.
First of all, are we talking about heat or cooling?
In what climate?
Ceiling height?
Insulation?
And certainly others I am mot thinking of.
35,222
Units of area is length x length, hence square footage is feet x feet = feet squared or feet^2.
Google search suggests about 30-50 BTU per sq. foot for heating.
MrSoftware
Joined Oct 29, 2013
2,273
There's quite a bit more to it. What you really need to be accurate is total square footage of the ceiling, walls and floor, insulation factor for each surface and desired temperature differential for each surface. Then you can calculate heat loss through each surface and determine how many BTUs are required to maintain some temperature. It's a bit involved, so when you're reading the suggestions on the box for an A/C or heater unit, they just assume some averages for most of it. Tell us more about your ultimate goal and maybe we can help more. i.e. are you trying to pick out an A/C unit for a room, or are you trying to build a calorimeter?
MrSoftware
Joined Oct 29, 2013
2,273
These recommendations are so general they're almost misleading. For example, a small 6k BTU unit will keep our master bedroom cool at night, but the same unit can barely keep my similarly sized garage below 90 degrees on a summer afternoon. There are just so many variables.
35,222
It is well understood that the TS has omitted a lot of important parameters.
For example, heating/cooling, and “I live in the USA”, Texas vs Colorado?
ronsimpson
Joined Oct 7, 2019
4,840
In Colorado you must build houses with 6-inch-thick walls for insulation. I have seen many houses in the south without insulation at all.
35,222
Let's be more specific.
For 2400 sq. ft in Zone 5, my Trane furnace is 80,000 BTUs.
That works out to 33 BTUs per sq. ft.
MrSoftware
Joined Oct 29, 2013
2,273
I'm a S. FL native, the house I lived in as a kid had only concrete walls with no insulation. But it also did not have whole house air conditioning or heat at all. Now that houses have air conditioning, insulation is a lot more important for your power bill. Though the temperature differential isn't as bad as up north so they tend to skimp on the insulation, much to the disappointment of my wallet. If it's 100 outside and you cool the inside to 75, that's only 25 differential, compared to up north where I guess it could be 0 outside and maybe 65 inside?
