MisterBill2
- Joined Jan 23, 2018
- 28,392
Tony, thanks for drawing what I was hoping to be describing in post#38. Flat belts instead of V belts but that is the concept. I once owned a motorbike with that arrangement, except that the engine used a V belt to drive a sprocket that drove the chain to the rear wheel. No racing starts unless one wanted to buy a new replacement belt, but once rolling all was well. I believe that it was a REO brand engine.The small pulley (in this case) represents my 4 HP Briggs & Scrapiron motor and the large pulley represents the drive axel. The tensioner swings into and away from the belt applying enough pressure for the large pulley out-feed side and the in-feed side of the small pulley to provide plenty of friction to pull the wheels into motion. As the tensioner swings away the belt slackens and slips, thus, not driving the go-cart. On my go-cart, the driver had to hold the clutch pedal down in order to drive. Safety "Dead-man" arrangement. You couldn't accidentally drive the cart without someone to step on the clutch pedal. Anyway, the drawing below describes what I'm thinking - as opposed to your 1 1/2 wrap solution.
