- Joined Jan 23, 2018
- 28,160
OK, and I am glad that you have a good handle on that part because it is beyond my realm of competence.It is a RWD normally, with 4WD selectable by one lever, and 4WD HI/LO selectable from the other lever.
The helical portion of the gear is used (I believe) during 4WD HI (1:1 transfer case ratio) and the straight-toothed portion (I believe) is engaged during 4WD LO (2:1 transfer case ratio).
I have read on the internet that this Dana 20 transfer case can be easily made to have a 4th operating mode (FWD) simply by removing some pin or block (I can't remember exactly and not really curious) from the transfer case.
But in any case, there is most definitely at least one (probably two) approved operating mode where that straight toothed portion is not engaged with anything and all the side load from the gearing is handled by the bearings in the transmission and intermediate housing.
