i found the foil continuity with the continuity test .. its the negative of 4148 close to R23 ..
Look at that first picture you posted. It almost clearly shows there is NO connection ....... especially in the area where the resistor lead is. The third picture you posted shows the lead of the resistor bridging the gap creating the short.
Again, I implore you to remove that damn resistor and see how the trace runs. That first picture you posted in post #50 is not as clear as the third picture in that post.
