I have this chip and i wonder if it's broken, there's a little notch on top.
Is the right question - I've seen internal eruptions "disappear" a bit of the encapsulation like that once or twice. Cosmetic defects like that are rare - but not impossible.Does it work?
It stopped working, hence the reason for probing about, which resulted in catastrophic eruption of the casing. The chip mentioned that is adjacent but opposite both share the same negative power plane. The positive plane is guarded by two parallel 40 amp fuses. I guess they couldn't find an 80 amp fuse ? ? ?Does it work?
