Good point, what resistance would you suggest? I'm a bit concerned about about damaging the inverter?The reading can occur due to leakage, especially using a sensitive high impedance meter for the reading, you would need to provide a resistance to ground and see if the voltage remains or collapses. if the latter, then it usually indicates the reading is just leakage.
