I am currently working on boost converter (3.3v input, 12v - 2A output ). I am using a LTC3872 chip (550kHz) and have done all the calculations following the datasheet.
However, I am confused over choosing the MOSFET. (Rds_on = 13mohms , Iin_peak = 8.9A). As the system gets powered by a Lithium-Ion battery I guess the Vgs should be around 2.5V?
I did simulate this circuit on LTspice however I'm not getting anymore than 6.6v output!
I attach my circuit diagram and chip datasheet.
Would appreciate it if you help me to pick an appropriate n- channel MOSFET, preferably non-SMD which i can test on breadboard.
LTC3872 Datasheet
LTC3872 Datasheet
