hello,
I am using this guide for my boost converter circuit:
https://learn.adafruit.com/diy-boost-calc/the-calculator
The problem is when I made this circuit on a breadboard it worked fine but when I soldered the components on a strip-board it shorted the power supply above 2A and the inductor started to heat. although the circuit on the breadboard naturally did short the power supply since the inductor gets energized but the one on the strip-board doesn't work.
What could be the potential problem?
