BJT saturation mode
Nikša
Joined Mar 26, 2018
86
So what is the reason small battery DOES get damaged in noted cases of transistor failure. Is it because small and big battery are back to back, that is, - to - and + to +?
ericgibbs
Joined Jan 29, 2010
21,575
hi N,
If there is a high value load resistor between the two batteries, that will limit the current flowing from the big battery to the small battery, the small battery will not be immediately be damaged, it could fail later due to over charging.
Why don't you study a more practical/everyday configuration of the BJT, it will help you better understand the transistors operation.?
E
Nikša
Joined Mar 26, 2018
86
hi N,
E
I know big enough resistor will limit the current, that is besides the point. In the last example of common base we saw batteries in series and no damage to the smaller one as Danko nicely pointed out. Consequently, i asked why in the case of transistor failure in common emmiter configuration, smaller battery does (potenetially) get damaged. In both examples current flows from big to small battery, but only in the latter damage potentially happens. What is the cause of this, is it the polarity or? To address your question, i study those too, i just want to clear up these details.
Jony130
Joined Feb 17, 2009
5,600
To damage, the battery you need "short" directly two batteries together so that the short-circuit current will start to flow.
