bjt op amp design need help with second stage
crb123
Joined May 16, 2017
8
Hello, i am trying to model op amp to boost high impedance (10-100)microVolts to (plusMinus 1volt )...please see attached simulation design, from first stage i have boosted (input delta20uV) to (output (pink wave)about delta49mV). which is at dc level +3.23V.......but am having problem adding the second stage....(blue wave) possitive peak is good to 1.5v but negative peak doesn't look right 1.jpg2.jpg.....any suggestions please...or links to resources i could look into...thank you.
ci139
Joined Jul 11, 2016
2,034
Q18 Q10 for output is a bit . . . not too good design
(Q17 Q5) (Q7 Q6) is not good practice (slows down the input and phase - further causes instability)
you have an open loop configuration (there's no negative feedback) -- so that shows your voltage gain is poor - 50k eg 50000x is poor 100000 is moderate poor 200k is ok (the higher the gain the better the precision and the higher the upper bandwidth) , , ,
. . . although for starting anything above 200x is a good achievement /// use ±10V and higher supply = you will avoid common mode and offset problems . . .
there is no reason to panic about ↑↑↑ just do it again (& again(& again(& again))) and do it better until it works as you planned
________________
It takes a warm up (i have not played around with these things lately) -- but i managed to quickly assemble a simple/slow/poor Op-Amp works about up to 1kHz
Simple - OpAmp Dev rig - FD -- Ni - Cfg.pngSimple - OpAmp Dev rig - FD -- iN - Cfg.pngSimple - OpAmp Dev rig - TD -- iN - Cfg.png____________________
+the dev. configuration :
/// it does not much work without feedback . . . and has a poor DC performance -- but it does somethingSimple - OpAmp Dev rig - TD -- Ni - Cfg.png
ci139
Joined Jul 11, 2016
2,034
Yes, . . . speak up . . . ask questions
? What is the aim planned use of this device -- supply- input- output- frequency- (output)power- range , where it goes when ready (target app.)
? Is there a specific example design you are modifying -- ? a link to // would help to match . . . also "to do next" dev. plan
i just provided an example how you can tweak a random op amp to it's better form → keep it in the unity gain cfg. at the supply median , vary supply , amplitude , frequency . . . try to extend the range for each
the option B is to make a computer program that computes (attempts to bind) your !existing/fixed! schematic to it's optimum // while the previous option allows you to apply random modifications where they seem to be required . . . and test whether you were thinking correct
crb123
Joined May 16, 2017
8
Thank you...again....this a a homework!! ...so not much for practicality......
Conditions given supply limited to +/-4.2V....input signal (10-100)uV @40Hz....with high impedance of 20Meg in parallel with 10pF. Output required +/-1V. Thats it.
I have input signals passing through darlington emmiter follower to overcome that high impedance input....
ci139
Joined Jul 11, 2016
2,034
if you 're allowed to use j-Fets for input your life gets a bit easier
yes but your errors by shoulder multiply that way -- say \[ G_\text{TOT}·\left(1+\frac{\Delta G_\text{TOT}}{G_\text{TOT}}\right)=G_1·\left(1+\frac{\Delta G_1}{G_1}\right)·G_2·\left(1+\frac{\Delta G_2}{G_2}\right)·G_3·\left(1+\frac{\Delta G_3}{G_3}\right) \]
for the school prj. you ... should ... follow ... a known example = if you have earlier v. of this circuit of yours - pick the mod that resembles to anything in a text book the most
true but your experiment setup has double that
your OUTP graph looks logarithmic but it may be due you are using the CE OUTP Stage . . . e.g. a Class A
basically the diferential input stage just provides the "differentiating" e.g. common signal cut off -- the gain is got by voltage amp that usually follows the dif. inp.
ci139
Joined Jul 11, 2016
2,034
what is your exact task get amplification of ( \( \frac{100µV+10µV}2±\frac{100µV-10µV}2 → 0V±1V \) ) "=" ( \( 55µV±45µV → 0V±1V \) ) →
→ \( K_U=\frac{1V}{45E-6V}=\frac{1E+6V}{45V}=\frac{200'000}{9}=22222.222...≈22k \) . . . using 1 opamp only ?? ... and that opamp must be self invented ??? // or can you use readily avail op amps ?
the high sensitive old/simple opamps are :
  1. LM201 (input stge + more @ pg.13 , Vos = 700µV)
    ↕ cross-referencing the circuit diagram avail here ↕
  2. LM208 (erroneous schem. @pg.3 , Vos=700µV)
  3. OP07 (Vos = 30µV)
_______________________________
About using multiple stages to get your high gain :
LM201 see "Instrumentation amplifier" pg.11 (double op amp)
https://en.wikipedia.org/wiki/Instrumentation_amplifier (multi op amp)
AN-32 FET Circuit Applications see "FET Op Amp" (with FM3954) pg."10"/11 (j-Fet amp from bipolar) + Fig.7 pg.7 , Fig8 pg.8
_________________
it seems you may need to use both -- the 1-st to reduce impedance , the 2-nd to add voltage gain ← to do this with single op amp is a bit demanding ???
