Hi, I am designing a visible light communication system. The LED has to be modulated directly with my data signal. I have generated the data signal from a waveform generator (200 MHz frequency). The bipolar signal is biased with some voltage using tee-bias since the LED cannot respond beyond threshold and for negative voltages. But the LED needs a current signal to drive on. So, I need to use a resistor to convert my voltage signal into current.
If a voltage signal is input to bias, and the bias is supplied with say 2 Volt, then the output signal is a voltage signal offset by 2 V.
But, if a resistor/potentiometer is added in the path of dc supply and bias supply port, what type of signal do I expect at output. Is it a current signal that can modulate LED (or) voltage signal with an offset (or) both the same.
i have attached the two possible designs below. Which of these can give an output current signal suitable for my LED.
