Audioguru again
- Joined Oct 21, 2019
- 6,826
Your negative input signal voltages are destroying the PNP input transistors of the LM358.
The datasheet says the absolute maximum allowed negative input voltage (with respect to the grounded pin #4) is -0.3V so that the forward-biased base-collector diode of a PNP input transistor is not burned out.
