Do NOT try to control the bias current by directly establishing a value of Vbe. Remember, that plot is for a TYPICAL transistor that has a junction temperature of 25°C. It's highly unlikely that the transistor that you will put in your circuit will be typical. The transistor you actually use may have a significantly different Vbe at this operating point. You need to design your circuit so that the specifics of this relationship have little effect.Hello WBahn,I am trying to understand the logic ,
you picked a point in figure 9 of the data sheet in which Ic/Ib=10 and Vce_sat=100mV
Ic=20mA Ib=2mA
this is my saturation conditions. In saturation i cannot assume Vbe=0.6 volts.
in the circuit bellow(please disregard the resistor value) i can controll the Vb voltage because its a voltage devider.
so Ic/ib Is the HFE (beta) value? correct?
there is also the Vbe sat plot .
So i take 20mA line up to the Vbe sat plot and get that given Ic=20mA my Vbe(sat) will be 0.8 V?
Correct?
You have the base current going the wrong direction. For a PNP, the base current is coming OUT of the base.Hello ,from figure 9 of the data sheet if we take the Ic=20mA so Ib=2mA point in Saturation state our Vce=0.1V and Vbe_sat =0.8V given 20mA.
Assuming i am correct i have a problem with the KCL in the base junction.
I know the Ib=2mA and i have voltage divider.
how do i combine the two to know what current flows at R1?
Thanks
https://pdf1.alldatasheet.com/datasheet-pdf/view/11478/ONSEMI/2N5087.html
Why do you want force 20 mA of base current?You don’t use a voltage divider. You don’t set the voltage, you set the current and whatever the resulting voltage is, it is. The current is not critical, if it is 10 mA or 40 mA it will barely change the operation.
First, remove R3, it serves no purpose and just complicates the calculation.
Next, remove R1, R2 and and V1. They are not needed.
Now put a resistor Rb from the base to ground. Calculate Rb to give 20mA of base current assuming Vbe is -0.6V as follows:
Rb = (5-0.6) / 0.020 = 220
This is the same calculation you use for current in an LED, which is no accident since you are calculating the current through a diode.
20mA collector current and 2mA base current would give 22mA emitter current (not that it makes much difference to the outcome)Assuming that the device is in saturation to a degree that the beta has been reduced to 10, that means that the base current would be 2 mA, making the emitter current 18 mA. Thus the voltage across R3 would be 1.8 V, making the Vce of the transistor 1.2 V, which means it is NOT in saturation. Even with infinite beta, the Vce would still be 1 V, placing it still in the active region.
Duh, you're right. I sometimes makes goofs like that working with PNPs in my head instead of sketching something out. Thanks for pointing it out.20mA collector current and 2mA base current would give 22mA emitter current (not that it makes much difference to the outcome)
You've stated that your goal is to put the transistor into saturation.
Will 20 mA of collector current do that?
With 20 mA of collector current, the voltage drop across R4 will be 2 V.
What about their values is causing you to choke?Hello WBahn, I am trying to use the data sheet shown bellow
in figure 9 i saw Vbe sat and Vce sat curves an i choke their values at 20mA.
Why its wrong?
How to properly find values?
Thanks.
...higher than what?No PN junction is actually a constant-voltage junction. As the current increases, the voltage increases. When the transistor is in saturation, more base current is needed for the same collector current, thus the Vbe will be higher.
REF: When the transistor is in saturation, more base current is needed for the same collector current, thus the Vbe will be higher....higher than what?
Yeah. So? The post I was responding to seemed to be caught on why Vbesat was so high at 20 mA of collector current. Maybe I inferred incorrectly.I think - as mentioned in my answer (post#32), the drastic increase in the base current is caused by the base-collector junction which during saturation mode is also biased in forward direction (in addition to the base-emitter junction).
The voltage Vbe will only slightly be increased (in comparison to linear operation) - and can be still approximated with Vbe=0.7-0.75 volts.
If you are trying to explore the saturation behavior of the transistor, get rid of things that just complicate stuff. Get rid of R1 and R3 and tie the emitter directly to Vdd.Hello ,I have swept the X resistor value shown bellow.
using VCE i know that when its small then its saturated.
but the saturation current is very small.
also Ic/Ib is about 2.
How do i increase the Ic current?
How do i increase the HFE?
Is there some intution to get my Ic/ib=10 in the circuit bellow
Thanks.
| T | Analog video switch circuit - Unsure about DC biasing. | Analog & Mixed-Signal Design | 13 | |
| V | Transistor biasing homework problem | Homework Help | 20 | |
| D | Op-amp biasing not working as intended | Analog & Mixed-Signal Design | 8 |
