BD140 1.5A 5v resistor
Isaacte
Joined Nov 9, 2019
12
Hi I'm new to using transistors
I saw a post for the same transistor and same current(1.5A) needed however I am using 5v instead of 12v. I'm asking what base resistor I need and maybe if you could tell me how much the voltage would drop. Thanks in advance.
TeeKay6
Joined Apr 20, 2019
573
We cannot tell you anything useful without seeing your proposed schematic; please post a copy.
AlbertHall
Joined Jun 4, 2014
12,629
What resistor? How is the transistor connected?
Can you post a clear schematic please (hand drawn is fine)?
Dodgydave
Joined Jun 22, 2012
11,395
Looks like you're switching the load posative lead with a Pnp, you can use a 1 to 4.7K resistor, ideally what type of transistor are you using will help...
Isaacte
Joined Nov 9, 2019
12
Looks like you're switching the load Negative lead with a Pnp, you can use a 1 to 4.7K resistor, ideally what type of transistor are you using will help...
Thanks for the replies. Should I be switching the positive side with a PNP transistor. Also, would there be any difference with 1k to 4.7k resistor or would they do the exact same thing? Thanks
AlbertHall
Joined Jun 4, 2014
12,629
What transistor are you using?
The necessary value of the resistor depends on the gain of the transistor. To determine that we need to look up its datasheet.
Bordodynov
Joined May 20, 2015
3,426
See. The diode may not be used, but with a weaker load, it limits the saturation and speeds up the shutdown of the powerful transistor.BD140.png
AlbertHall
Joined Jun 4, 2014
12,629
It's a bd140 transistor. Isn't the transistor on the positive side?
Yes, the transistor is on the positive side and that is fine.
The maximum rated collector durrent for the BD140 is 1.5A so you would be pushing your luck using it with a 1.5A load as your diagram says. You really need to leave a safety margin, perhaps using a transistor with maximum current rating of at least 3A. Also the gain would be rather low at that current requiring lots of current from the arduino pin.
[EDIT] If you look at @Bordodynov circuit you will see an extra transistor to get around the low gain problem.
Isaacte
Joined Nov 9, 2019
12
The 1.5A is only used for a few seconds, so it should be ok. I used these resistors as I had them lying around and I want to make the project as soon as possible. Someone send use a resistor of 1k to 4.7k, do you know which resistor would require the least base current from the Arduino. Thanks so much!
AlbertHall
Joined Jun 4, 2014
12,629
If the maximum possible current is 1.5A then the resistor must supply sufficient base current for that. From the datasheet the typical gain may be just 30. So the base current would need to be 50mA which is above the maximum for the arduino. If you want to use the BD140 then you need the extra transistor as in post #12.
BobTPH
Joined Jun 5, 2013
11,553
You will need 150 mA. The Arduino cannot supply that, so you need another transistor to raise the base current to that level.
Bob
Isaacte
Joined Nov 9, 2019
12
That's a bummer. Do you know of any transistors that can be turned on with Arduino and can handle 5v and 1.5A. thanks!
