AlbertHall
- Joined Jun 4, 2014
- 12,626
With a MOSFET you don't need a resistor at all and there will be less heat produced.
Would a TIP31C work or a L7905CV (as I have them) or would I still need another transistor.I would recommend a P-channel MOSFET for the job.
This would be good: https://www.digikey.com/product-detail/en/NDP6020P/NDP6020P-ND/1055922
Thanks. Can I just re arrange my circuit so it's on the negative side?The 7905 is a negative voltage regulator and the TIP31C is NPN so neither of those is going to help you.
I think the load is taking a maximum of 1.5ATo control the output current at 1.5A then you must add a current regulator circuit.
Yes, you could and the TIP31C is rated for 3A so that's OK, but its gain is low so you would still need a second transistor to boost the arduino output current.Thanks. Can I just re arrange my circuit so it's on the negative side?
I think you will need a small transistor to drive the relay from the arduino.I think I will use a relay but thanks for everyone's help again.
You can get boards with transistors already on them. Thanks for all your help.I think you will need a small transistor to drive the relay from the arduino.
Indeed you can and that makes a simple solution to the problem.You can get boards with transistors already on them. Thanks for all your help.
