BCD 7 Segment up down counter with Thumbwheel switch
KimChuan Tham
Joined Jun 26, 2016
9
Im currently trying to build a circuit on BCD 7segment up down counter with thumbwheel switch and im totally clueless on what kind of components should be used and how the circuit is to be formed. Please help me
GopherT
Joined Nov 23, 2012
8,009
You can get a thumb-wheel switch with a binary-converted-decimal (BCD) output. BCD is a 4-bit representation of decimal numbers 0-9. (Google BCD for clarity).
Then get a CD 4511 chip that accepts the BCD "data" as an input. The CD4511 will output all the signals for segments a to g for a common anode 7-segment display. The output will display the new digit as your thumbwheel sends the new BCD value to light the next digit - up or down depends on which way you turn the thumb wheel.
Something like this where your BCD thumbwheel switch is shown with four separate (simplified) switches. Depending on your thumbwheel, you may need pull-up resistors.
KimChuan Tham
Joined Jun 26, 2016
9
Do you mind helping me design the circuit out? I really have 0 knowledge on how its gonna be
GopherT
Joined Nov 23, 2012
8,009
Something like this. You'll need to read the datasheet for the thumbwheel switch that you have to get the right pins to the right place (and google cd4511 to get the right pin assignments for the cd4511 and so on. Datasheets are your friend.
38,767
If you want the thumb-wheel switch to input the count value to an up/down counter then you would also need a BCD counter, such as the CD4510, to go in front of the CD4511, which is just a BCD to 7-segment decoder.
Or is all you want just to read out the thumb-wheel BCD value?
KimChuan Tham
Joined Jun 26, 2016
9
what i need to do actually is something like a stop watch and an alarm. i need it to count downward and also count upward. what my teacher require me to do is to use 7 segment and thumbwheel switch. the rest is for me to find out. thats why im seeking help if someone knows how the circuit is suppose to be like
GopherT
Joined Nov 23, 2012
8,009
What is the thumbwheel supposed to do? Set the start time of a countdown timer?
GopherT
Joined Nov 23, 2012
8,009
yeap it is to set the time
Then this can be done with:
- 555 timer pulsing away (or CD4060 if you want higher accuracy) sending signal out to...
- CD4510 to convert those pulses to a binary value and send that binary value out to...
- CD4511 which translates the binary value to drive the segments of a...
- 7-segment display
You will need switches to
- "latch" the value of the thumbwheel (when needed)
- tell the 4510 chip to count up or down
- clear/reset the 4510 chip to restart (could be the same as the latching switch)
Start with the Datasheets and there are plenty of circuits online that you can search to get you started.
If you are so lost that this does not help you, go talk to your professor - he needs to know that either:
- his lectures are not working
- you do not have the background to be in this class
KimChuan Tham
Joined Jun 26, 2016
9
- 7-segment display
will it be easier if i use a microcontroller?
30,802
Probably yes, but you would have to adopt some programming skills.
KimChuan Tham
Joined Jun 26, 2016
9
Just to clarify, what if i dont want any programming to be included in my project. And only 7segment, thumbwheel switch(to set the numbers), and ics to be on my breadboard, what ics do i need to use and is there anything im missing out like a counter or something
shteii01
Joined Feb 19, 2010
4,644
Do a block diagram, label the blocks according to the function you want them to perform.
38,767
You don't seem to be tracking the posts. :rolleyes:
It has already been established that you need a counter and a part number has been given for that.
