Battery simulator
oferorgal
Joined Oct 10, 2021
I want to design a battery simulator circuit to test my board. My board connects to a single cell li-on battery, 3.8V 2400mAH and it has a wireless charger circuit with up to 400mAH charge.
The battery simulator needs to provide up to 1A to the board and to be "charged" at 400mA.
I've tried several solutions:1634054915734.png
and more from: https://www.powerelectronicsnews.com/using-a-battery-simulator-to-stress-test-charging-systems/
But nothing seems to "charge".
Any help will be great.
Ofer.
Audioguru again
Joined Oct 21, 2019
6,826
A Lithium single cell battery charger must keep its voltage no higher than 4.20V. The circuit you showed does not detect and has no control of voltage.
A Lithium single cell battery charger must detect the charging current and must disconnect the charging when the charging current drops to 1/10th the mAh rating or less. The circuit you showed does not detect charging current.
You have a Mosfet that shorts Vout. Why?
