so basically join the 2 middle connections which on the diagram is purple with some wire then join another bit of wire to that "purple" wire and to the board where marked CT?No, you're looking AT a center tap transformer. Just make a connection where the purple mark is on the drawing of the secondary windings and THAT is the center tap. See? It's in the center of the windings!
And you have to use it. Connect a wire from the center of the output windings (the purple mark) to that place on the circuit board marked, "CT". You will have to use a piece of wire to connect the center tap of the transformer to the place marked, "CT". It should be about 16 or 15 gauge wire. (Somebody translate that into British for me.)
Or you can go look for a center tapped transformer with the wire already attached.
The circuit indicates capacitors are present after the rectified AC input which will raise the DC to ~9vdc.you lost me on the capacitor filtering![]()
