Thank you so much for your reply ।।।If you are switching a load then basically you don't calculate Vgs; you just switch the FET hard on. If the p-FET is specified as a "logic-level" type then Vgs = about -5V should do that. If it's not a logic-level type then Vgs = about -10V is the usual value.
Vgs means "V(gate) minus V(source)". If the p-FET source is at 3.3V (Vcc) and the gate is at 0V then Vgs = V(gate) - V(source) = -3.3V.where is that negative Vgs comes into the picture.
Thank you so much for your kind reply and time.Vgs means "V(gate) minus V(source)". If the p-FET source is at 3.3V (Vcc) and the gate is at 0V then Vgs = V(gate) - V(source) = -3.3V.
To ensure the FET is switched fully on you would choose one with a rated Vgs(threshold) of around -1V.
When the FET is turned fully on the voltage drop from drain to source will be small, determined by the product of current and the drain-to-source resistance Rds(on), which is a figure you'll find in the FET's datasheet. The lower the value of Rds(on) the better.What about Drain/Source voltage
By definition, Vgs is Vg - Vs.vgs is simply the difference of the voltage at the gate and the source
That is definitely not true, there is no universal rule that says that an N-fet has to have its source connected to ground. Otherwise you have it correct.Vs= 0 (since source voltage is always at the ground level)
| Thread starter | Similar threads | Forum | Replies | Date |
| F | Basic Amp Circuit Question | Homework Help | 4 | |
Best First Projects for Learning Basic Electronics? | General Electronics Chat | 60 | |
| P | Basic 'clap ON' switch. | Sensor Design & Implementation | 16 | |
| C | basic questions about soldering. Beginner | Technical Repair | 47 | |
| W | Basic impedance calculation with LM741 op-amp buffer circuit | Homework Help | 8 |
