Bad relay for clutch motor on my Lg washer PCB.
subhuman000
Joined Apr 14, 2019
Can anyone tell what relay would be related to the upper blue terminal BL2 or does anyone have tech access to Lg's component level schematics for part# EBR79505204. I'm not sure which component on the board is responsible for sending 120v to the clutch motor on my top load washer model Wt1701cw. I think it may be the upper song chaun relay. The other blue terminal (BL3) is for the drain motor so I figured the two black relays nearby are related. Just guessing though.20190414_232006.jpg
MaxHeadRoom
Joined Jul 18, 2013
30,887
Check the PCB under the relay, in many cases the foil has burnt away from the pin.
Or even on the socket end foil.
It should be relatively easy to trace the conductors that plug into BL2.
Max.
