Power amplifier repair question.
The mono block powers on with no issues. The light bulb is off when connected to the dim light bulb tester. All fuses good, power supply voltage present +68 V and -68 V. However, the amp outputs no sound. All output MOSFETS have been replaced. I have found earlier three were bad. With speaker connected (amp powered off), I can hear the click in the speaker when power supply terminal blocks being attached to the main board.
I do not own an audio generator or oscilloscope, just DMM. I guess, the first question if would be possible the troubleshoot the unit without the measuring equipment.
What transistors needs to be checked in first place in this case?
Thank you in advance.
