Average Voltage
Agonche
Joined Aug 26, 2011
30
I hope that I'm not disturbing you with a similar question again.
I just wanna make sure I am correct on this one.
______________________________________________
I have to find:
  • Output Waveform
  • \(V_{AVG}\)
Here's the circuit:
\(V_o\) terminals are as usual.
\(V_i=6sin(\omega t)\)
_____________________________________________________
\(V_i>2V\), D1 ON, D2 OFF, \(V_o=3sin(wt)+1\)
\(V_i<-4V\), D1 OFF, D2 ON, \(V_o=-4V\)
\(-4\leq V_i \geq 2V\), D1 OFF, D2 OFF, \(V_o=V_i\)
* \(V_o\) waveform:
* \(V_{AVG}\):
which gives as a result \(V_{AVG}=-0.155847\)
_________________________________________________________
Am i right ? Im not sure because this is the most complex waveform I solved.
The Electrician
Joined Oct 9, 2007
2,970
I see that you found Mathematica, presumably on your school's network.
I solved the problem using the simpler method I demonstrated in the other thread. I get exactly the same result, so you're good to go. :)
