Attenuating a 5V DC waveform - is a JFET the answer?
danielantonic
Joined Sep 22, 2019
68
Hello
I have an arduino, 5V rail to rail op amp, and an AD9833 function generator, and I want to control the amplitude digitally. I have an MCP4725 DAC that I would like to use, and my research leads me to a JFET or MOSFET solution like this: https://amplifiercircuit.net/voltage-controlled-variable-gain-amplifier.html/amp
Is something like this the preferred solution, or is there something else I should consider?
38,572
I suggest using a multiplying DAC to directly control the signal amplitude, if you want to use a DAC.
The FET approach will likely introduce some distortion into the signal.
Audioguru again
Joined Oct 21, 2019
6,826
Daniel, I think the circuit in your first post will not work because the - input is a "virtual ground" with almost no signal level.
When the jfet conducts then it feeds the "nothing" on the - input to the +input and nothing will cancel.
The Jfet can make a voltage divider to ground with another input resistor or the Jfet can be places across R2 to reduce the opamp gain.
danielantonic
Joined Sep 22, 2019
68
So if my DAC was -5 to 0V instead of 0 to 5V, then the JFET design would work?
Audioguru again
Joined Oct 21, 2019
6,826
The circuit you copied already has a negative voltage fed to the gate of the Jfet to control its conduction.
The opamp has a positive and negative supply.
I simulated your circuit using a resistor as the Jfet. It does not work as an attenuator.
