Hahaha! No, nothing that fancy, I'm doing everything. I have the wood and can drill the hole. Am I drilling a hole so that the bottom of the pot goes in or just the knob part? I have a hand drill. The wood is just mdf, I have experience with drilling etc so I'm confident. Once I've put the pots in what's next? Heat sink? Where is that going? I've also got something that is a screw and a small bit of plastic. Where does that go?Remember that you want to mount and assemble the oven pot & SW before assembly. Have you checked the positioning of the knobs yet ? I would practice drilling the SW & pot holes on similar wood. Lili, do you have a drill press or is this work to be sub contracted out ?
Grateful for the suggestion! Not sure how I would do that practically. Some of the issue is I am struggling to "see" how things work/put together and that makes it difficult, if I could envision it a bit better I could do it.Please pardon me for sticking my head in. When faced with a similar problem, I solved it this way.
I found a thin piece of material (I used a piece of Masonite in the states. You could use a blank PCB board). I cut a rectangle out of it to mount the pots on. I’d make it wide enough so that there was space along the edges to mount it on the panel. Then, I cut holes in the backing wood to clear the entire pot body with wires. Attach the pot to this thin material. Then glue/nail the thin backing to the thick wood.
Since you’re using a hand drill, my second method won’t work. I used a Forstner bit to create a recessed opening for the pot.
Sorry, I interpreted your comment that you only had a hand drill as meaning it was manual. Not electric. ThIs hole would be through the remaining 4mm of wood. This 4mm would be used to attach the pot.Hi Bernard I have an electric drill and yes I have both spade and wheel bits. If I drill it the way you're suggesting I don't see how I can secure the pot to the wood, please bear in mind that I need to add a "chuck" (for want of a better word) so that the knob will fit and that will take up another 10mm. Mouser have been in touch and say they might be able to help so I may just get a longer Pot from them. Be easier methinks.![]()
Sorry I'm still not following the wood is about 10-12mm the shaft is about 10mm by the looks of things. I need space to put a chuck on (which is the bit that holds the knob) plus the knob to turn so this needs extra space too. I don't think that has been accounted for. Are you saying to mount the pot within the whole so it sort of wedges in and then how would the wires attach to it? Sorry but it's not very clear what you're saying, I think I really need a longer shaft.Sorry, I interpreted your comment that you only had a hand drill as meaning it was manual. Not electric. ThIs hole would be through the remaining 4mm of wood. This 4mm would be used to attach the pot.
Once you drill out the recess that Bernard described, you would drill a hole in the center, which would allow insertion of the threaded connection on the pot. Then the knob would attach to the protruding shaft.
Besides the hole, Bernard explained how to drill additional holes which were cleaned up with a chisel to leave space for the wires.Sorry I'm still not following the wood is about 10-12mm the shaft is about 10mm by the looks of things. I need space to put a chuck on (which is the bit that holds the knob) plus the knob to turn so this needs extra space too. I don't think that has been accounted for. Are you saying to mount the pot within the whole so it sort of wedges in and then how would the wires attach to it? Sorry but it's not very clear what you're saying, I think I really need a longer shaft.
You want to make space for the pot and it’s wires, leaving enough wood to attach the pot.
I must admit I don’t understand what the “chuck” is. I’m used to knobs that directly attach to the pot shaft. Usually, the shaft and knob has a flat edge, to keep the knob from rotating on the shaft.
And in mounting in this manner, the knob is slightly above the mounting plane. Thus, there is no requirement for space to allow the knob to rotate.
Hi Bernard and @djsfantasi apologies that I've been as clear as mud. Firstly no the shaft really isn't 15mm it's shorter and I think that's where the problem lies, it barely pokes out the other side of the wood and the other shaft is even shorter! Here are the knobs I'm using. What I am calling the "chuck" is the coloured pieces, these fit onto the D shaft and then the knob goes onto them.The pot & SW have a 6.5 mm threaded bushing, pots with longer bushing , 10 mm, would still need to have a recess for either the nut or the pot body. On pot, the shaft is 6 mm dia. & 15 mm long & protrudes thru the bushing of 8 mm OD. The shaft has a D cross section 8.5 mm long
which goes into a "chuck" or knob D shaft adapter which then goes into a knob. The knob is on the top on cross section drawing, pot & SW go into the recesses held in place by nuts on top under the knobs. The heat sink is between the pot & SW shown on drawing.
THANK YOU!!!!! I don't know why but it's as though a light has gone on with this picture. I really get it now, cool. I'll do that today. Thanks for being so patient and explaining.Here’s a side view cross section of the wood where the pots are mounted. Note where the wood is drilled out for the body of the pot. Plus where the wood is drilled and chiseled out for the terminals and wires. And finally note the center hole where the pot is inserted. When prepared in this manner, the entire shaft protrudes leaving room for the chuck.
Yeah I get it now Bernard, thanks so much. Like I said to DJS Fantasi sometimes the problem is I can't envision it but the moment I do I'm good to goOn pot, 15 mm is from body to end of shaft, 15 mm - 6.5 mm bushing = shaft length of 8.5 mm, plenty for adapter
