Arylic Up2Stream Amp pinout ?
oslosl
Joined Jan 13, 2023
270
I have 3 push buttons (with a common wire). How do I connect them to control power, volume up, volume down of my Arylic Up2Stream Amp ?
28,322
To delete you simply select "edit" when you view it after posting.
BUT understand that you can also add a lot more information, if you have it. AS an alternative, if you have information about the remote capabilities of that amplifier, you could add that information.
oslosl
Joined Jan 13, 2023
270
I did get an answer from the Amp supplier, Arylic, but it only partially works.
Power on/off: ADC_KEY to GND works
Volume up: GPIO1 to GND works
Volume down: GPIO2 to GND don't work
Annoying.
