What are these? Are they supposed to help in desoldering? I can't any information on "desoldering needles".
I usually use a spring loaded solder sucker. If I have a lot of components to desolder, I use the desoldering attachment with my hot air tool. I haven't used solder wick in decades.Ever remove a through hole component and then find the solder wick just will not get the hole cleared?
Yep...they're solder sucker cleaner outters. If you have a commercial grade desoldering station, they're indispensibleI'd use them to clean my solder sucker, but that's about it.
