Arduino Uno ADC accuracy
Reloadron
Joined Jan 15, 2015
7,891
It did spin off from the other thread you mentioned, but I thought this warranted its own thread since my Arduino ADC inaccuracies are there regardless of what's feeding it. I think I've got a decent handle on the current-to-voltage conversion aspect of the project for now (many thanks to everyone in the other thread!)
I absolutely agree.
I figure it this way. In its basic state the Arduino is a 10 bit A/D resulting in 1024 quantization levels between 0 and Vref so using 5 Volts as Vref the best resolution we will see is just about 4.88 mV. With that in mind if I convert 0 to 50 Amps RMS to 0 to 5 VDC and do it linear I can scale things for 100mV/Amp. Even if my 10 bit resolution was 5 mV I could still resolve about 1/20 Amp. That being good enough for measuring household current.
Ron
smooth_jamie
Joined Jan 4, 2017
107
I had to alter my reference in my sketch as it was giving a value of 1023 at just 4.7V. I think it's probably because it's a rip-off clone-duino nano.
If you require a more stable reference voltage, you can purchase the AD584 on a breakout board, and it gives 2.5V, 5V, 7.5V, and 10V at very stable reference levels. Mine cost £2 from eBay.
philba
Joined Aug 17, 2017
959
The reference comes from the ATMega328 so I doubt it's the clone.Especially if you are running off USB. I'd check your supply voltage - that's more likely the source of the problem. Arduinos are basically just a glorified breakout board so the clones will have few differences from the genuine ones (usually a cheaper USB serial bridge, VReg, and connectors).
And, yes, if you care about the ADC reference, get an external one like you pointed out - genuine Arduino or not.
