I am looking to build a charger for my Prius Gen.3. Hybrid Battery.
The nominal voltage is circa 235VDC, which can peak at 250VDC. The charging / discharging current will be no more than 1.5A
I want to use an Arduino Uno to modulate mosfet(s) using the controller via PWM to charge the main hybrid battery.
I've looked around for example circuits but most off-the-shelf kits will not handle the voltage and power demands.
The closest I have come across is attached in a PNG below.
Any ideas or recommendations?
Thanks,
Alan.
Thanks,
Alan.
