Arduino photo resistor readings question
sstavrou
Joined Jun 14, 2017
Hi all, I'm new to all this so I got some noob questions
so in a voltage divider with a photoresistor:
1 what difference would a 300Ω resistor have in my analog readings in contrast with a say 10kΩ resistor?
2 would my readings theoretically range from 0 to 1023 regardless of the resistor used?
3 why is 1023 the limit?
Thx in advance
dl324
Joined Mar 30, 2015
18,471
Welcome to AAC!
That depends on the resistance of the photoresistor.
Depends on the voltage across the resistors, the light impinging on the photo resistor, and the resolution of the DAC.
Need more information. Are you using a DAC with that resoultion?
EDIT: Meant ADC in two places above, not DAC.
sstavrou
Joined Jun 14, 2017
I'm not using a DAC. I am using the analog pin of Arduino to analog-read the photoresistor linked with a 320Ω resistor with a 5v source
1 my question is not focusing on the particular numbers I'm wondering how the resistors affect my readings.
For example, would a higher resistance make my analog reading more sensitive/accurate to the LDR changes? should I pick high/low resistance for this task and why? or it doesn't really make any difference?
3 yes 2^10=1024 but how did this 2^10 occur? why is it not 2^8=256? or something else ;)
forgive my ignorance and thx again :)
yes your resistor value determines the sensitivity of the sensor, I would personally recommend a pot for this, ofcos you will only use two legs not three, this will allow you to set your sensor sensitivity easily depending on the day or time of the or so
I have never used an arduino before but on STM32 cortex-MO I can choose which resolution I want ( 8bit ,10bit, 12bit or 16bit) so I don't know if this is the case with arduino
sstavrou
Joined Jun 14, 2017
yes i just realised that the answer is in analogread method of arduino which has a 10 bit atd converter hence the 1024 values. and yes it seems that you can alter the range within the 10 bit limit i think.
thx all, made a bit sense now!
:D
be80be
Joined Jul 5, 2008
2,395
LDR is say 10 k you tap at center of 330 going to ground not much going to happen till the LDR goes close to the 330 value a 1 k or bigger would be better I use 1K to 10K
35,189
Try this simulation on a spread sheet.
Firstly, take your photo resistor and measure the resistance when it is dark. Measure the resistance when it is exposed to your maximum light source. Now you have two readings, Rmax and Rmin.
Plug these into a spread sheet column with 100 values from Rmin to Rmax.
Compute the output voltage of the voltage divider using whatever resistance value you choose for the other resistor of the divider.
Convert this voltage to an ADC reading from 0 to 1023.
Now try different values of the resistor and then choose the one you think is most suitable.
