Arduino Motor Circuit Only Getting Less Than 1V
brenduan
Joined Feb 15, 2020
I have built this motor circuit for my Arduino and when running it only gets less 1v and the motor spins very slowly and my bigger motor doesn't spin at all. I have attached the diagram that I followed below. The Motor should be getting 5v from the Arduino although something seems to be limiting it.
Parts:
270 Ohm 0.5 Watt Metal Film Resistor
1N4001 Rectifier Diode
2N2222A NPN Transistor
SamR
Joined Mar 19, 2019
5,535
The transitor switch is typically used to control a higher voltage to drive the motor. Please post your sketch along with the diagram so we can tell exactly what you are doing in order to knowledgeably comment on it.
BobTPH
Joined Jun 5, 2013
11,645
That circuit looks fine. Unless the motor is drawing way more than the 5V supply can give, it should work, assuming the pin driving the base is set to high.
Bob
Audioguru again
Joined Oct 21, 2019
6,826
You did not say so I am sorry that I must ask. Is it a 5V motor? What is its no-load running current and its stalled current ratings?
The loaded output of the Arduino is probably 4V and the transistor base is 0.7V so the 270 ohm resistor provides a base current of (4V - 0.7V)/270 ohms= 12.2mA. The transistor can saturate with a collector current of 12.2mA x 10= 122mA.
If the motor resistance is less than 4.8V/122mA= 39.3 ohms then the motor will not start running.
Measure the resistance of the motor while slowly turning it and post the lowest resistance it has when it is not on the circuit.
Reloadron
Joined Jan 15, 2015
7,940
How are you powering your Arduino board? If the board is being powered by a USB 2.0 port on a PC you likely will not get enough current from the 5V out pin of your Arduino board. You really want to get an external DC power source like a simple wall wart with the standard 2.1mm x 5.5mm DC connector having center pin positive. Like this one. The Arduino powers well from between 7 and 12 VDC external power. Also, the Arduino 5V pin is not an infinite source of power, it has limitations. You need to know the load current or in this case the motor current. The circuit looks fine so my money is on the inability of the motor to get its rated current and that assumes this is a general purpose 3 to 6 VDC hobby motor.
Ron
