Arduino Looping states in Void Loop help needed for a novice.
James90s
Joined Mar 3, 2021
31
Hello everyone.
I am still very new to programming an Arduino. I have this code that changes states, but it does not repeat. It works once and I then need to go through all the counts again to repeat. How can I keep each state repeating without having to go through the count again.
Any help would be appreciated.
Mod: use Code Tags.E
Code below.
C-like:
int button = 4;
  int pin2 = 2;
   int pin7 = 7;
    int oldstate = LOW;
     int count = HIGH;
void setup() {
  pinMode(button, INPUT);
   pinMode(pin2, OUTPUT);
    pinMode(pin7, OUTPUT);
void loop() {
  int buttonstate = digitalRead(button);
   if (buttonstate == oldstate && buttonstate == HIGH){
    if (count == 1){
     digitalWrite(pin2,HIGH);
        delay(400);
         digitalWrite(pin2,LOW);
          delay(400);
            delay(400);
              delay(400);
     if (count == 2){
      digitalWrite(pin7,HIGH);
        delay(400);
         digitalWrite(pin7,LOW);
          delay(400);
            delay(400);
              delay(400);
      if (count < 2);
      else
       count = 0;
        count++;
         delay(50);
      oldstate = buttonstate;
ericgibbs
Joined Jan 29, 2010
21,580
hi James.
Built the project,.
#1
Press p/b, LED1 flashes twice,
press p/b again LED2 flashes twice.
back to #1
What do want to happen.??
E
James90s
Joined Mar 3, 2021
31
hi James.
Built the project,.
#1
back to #1
E
Hello.
I want to build a light, but I would like it to have many modes like Christmas tree lights. So if I have 10 led's, I would like to click the button once and it moves to a list of coding on the first increment then the lights flash on and off, and repeat the same way until I press the button again and move to another the second state where it will flash in a different until I then press the button again and it moves back to its original state. Just like a set of Christmas tree lights with a controller.
ericgibbs
Joined Jan 29, 2010
21,580
hi James.
Look at this option, you can add more patterns and call them in an order to suit the project.
E
C-like:
int button = 4;
  int pin2 = 2;
   int pin7 = 7;
    int oldstate = LOW;
     int count = HIGH;
void setup() {
void loop() {
//   if (buttonstate == oldstate && buttonstate == HIGH){
    if (count == 1){
      pattern1();}
    if (count == 2){
      pattern2();}
    if (count == 3){
     pattern3();}
     if (count == 4){
     pattern3();
     pattern2();
     pattern1();}
      if (count < 4);
      else
      count = 0;
      count++;
      delay(50);
 //     oldstate = buttonstate;
void pattern1(){
        delay(400);
          delay(400);
            delay(400);
              delay(400);
return;
void pattern2(){
        delay(400);
          delay(400);
            delay(400);
              delay(400);
return;
void pattern3(){
        delay(200);
          delay(200);
          delay(200);
            delay(200);
              delay(200);
return;
James90s
Joined Mar 3, 2021
31
hi James.
E
C-like:
int button = 4;
  int pin2 = 2;
   int pin7 = 7;
    int oldstate = LOW;
     int count = HIGH;
void setup() {
void loop() {
    if (count == 1){
      pattern1();}
    if (count == 2){
      pattern2();}
    if (count == 3){
     pattern3();}
     if (count == 4){
     pattern3();
     pattern2();
     pattern1();}
      if (count < 4);
      else
      count = 0;
      count++;
      delay(50);
void pattern1(){
        delay(400);
          delay(400);
            delay(400);
              delay(400);
return;
void pattern2(){
        delay(400);
          delay(400);
            delay(400);
              delay(400);
return;
void pattern3(){
        delay(200);
          delay(200);
          delay(200);
            delay(200);
              delay(200);
return;
Thank you very much for this. Very much appreciated.
click_here
Joined Sep 22, 2020
548
Another nice little way of approaching this problem is to use an array of function pointers.
Each function in the array is a separate state machine (or just a normal function)
Here is a very generic implementation of this. I have not included a few functions, but it should be easy to work out what they do by their name.
"Please excuse the crudity of this model as I didn't have time to build it to scale or paint it"
Code:
typedef void (*functionPointer)(void);
int main(void)
    functionPointer handleLeds[] = {AllOnOff, RollLeft, RollRight}; // Names of the different functions
    int indexOfHandle = 0;
    int handleLedsLength = sizeof(handleLeds)/sizeof(handleLeds[0]);
    for(;;)
        handleLeds[indexOfHandle]();
        Delay1mSec();
        if(ButtonPressed())
            // Debounce and wait for button to be unpressed
            Delay20mSec();
            while(ButtonPressed())
                continue;
            // Go to next handle
            indexOfHandle = (indexOfHandle + 1) % handleLedsLength;
    return 0;
The advantage of this is that you add a level of abstraction, which makes your code easier to update/maintain
James90s
Joined Mar 3, 2021
31
Code:
int main(void)
    for(;;)
        Delay1mSec();
        if(ButtonPressed())
            Delay20mSec();
                continue;
    return 0;
Thank you very much for taking the time to do this for me. I very much appreciate all the help. As I find my way through Arduino.
click_here
Joined Sep 22, 2020
548
No worries - If you want any further help on anything suggested here, feel free to ask.
Here are two (quickly done) possible solutions to the functions - Remember that it will enter the function approx once a millisecond, so waiting 1000 is one whole second (ish...).
You would usually remove the "magic numbers", but once again, "Please excuse the crudity of this model as I didn't have time to build it to scale or paint it"...
Using a switch statement...
Code:
int AllOnOff(void)
    static unsigned int sequenceNumber;
    static unsigned int delayLoops;
    switch(sequenceNumber)
        case 0:
            AllOff();
            delayLoops = 0;
            sequenceNumber++;
            break;
        case 1:
            if(++delayLoops >= 1000)
                sequenceNumber++;
            break;
        case 2:
            AllOn();
            delayLoops = 0;
            sequenceNumber++;
            break;
        case 3:
                sequenceNumber = 0;
            break;
        default:
            sequenceNumber = 0;
Using a once per second fire...
Code:
void RollLeft(void)
    static unsigned int lastOutputNumber;
    static unsigned int loopCounter;
    const int numberOfLeds = 8;
    if(++loopCounter == 1000)
        unsigned int currentOutputPin = 1<<lastOutputNumber;
        for(int i=0; i<numberOfLeds; i++, currentOutputPin>>=1)
            if(currentOutputPin & 1)
                LedOn(i+1);
            else
                LedOff(i+1);
        lastOutputNumber = (lastOutputNumber + 1) % numberOfLeds;
        loopCounter = 0;
Sure, the timing won't be spot on, but it will definately be close enough for christmas lights!
James90s
Joined Mar 3, 2021
31
Code:
int AllOnOff(void)
        case 0:
            AllOff();
            delayLoops = 0;
            sequenceNumber++;
            break;
        case 1:
                sequenceNumber++;
            break;
        case 2:
            AllOn();
            delayLoops = 0;
            sequenceNumber++;
            break;
        case 3:
                sequenceNumber = 0;
            break;
        default:
            sequenceNumber = 0;
Code:
void RollLeft(void)
                LedOn(i+1);
            else
                LedOff(i+1);
        loopCounter = 0;
Thank you very much again for taking the time to help me. Very much appreciated.
