daily routine - state diagram [SOLVED]
Pushkar1
Joined Apr 5, 2021
416
I still feel like I'm not as good at drawing state pictures as I should be. So I thought I should try something simple first. I thought to myself that why not make a state diagram of daily routine I have decided to make a state diagram in which I want to show the complete status from waking up in the morning till going to sleep at night. Everything i do, it should be considering a state and the time i do it is considering the state of the input.
I think this is the method that will make it easier for me to create state diagrams for embedded systems. I would like to get advise from members I do not understand what can be my other inputs other than time
I would appreciate any suggestion, advice before making state diagram for daily routine.
Irving
Joined Jan 30, 2016
5,195
For every state there is a function that determines from a set of inputs, one of which could be 'time now' or 'time in state', what the followng state should be, the default outcome being 'no change of state'.
There are various ways to diagram this, but all show the conditions for transferring from one state to another. A common modelling method is UML, as described here.
click_here
Joined Sep 22, 2020
548
A state diagram is something that I have used for programming a few times and is really good when you are using a "state machine" architecture.
The more states you have, the more functionality you have.
You want to think about states that you might sometimes need, like picking up the toothpaste if you accidentally drop it.
It would be a great idea to make a small program that uses a state machine, because it is a strong architecture.
I suggest that you make a small program that runs off a state machine, something like: wait for button press, de-bounce delay, led on, wait for button to lift, led off. That way after you make your diagram you can test with some code.
The trick with making a state machine with code is to never use "blocking code" - That way you can introduce multitasking later on. (If you want to do that I'll explain when you get there)
Ya’akov
Joined Jan 27, 2019
10,294
UML is really great stuff but it is huge. I used it extensively because of its capacity for dealing with parallel and blocking operations at the same time which simple flowcharts can't do. But, I only used a subset of it. It has some very good tools.
Pushkar1
Joined Apr 5, 2021
416
I made a state diagram showing my daily activities. I look displayed time on my clock and I do following activity over time
This state diagram is not looking as I wanted to show. There are two drawback in it.
1. In any state diagram, there should be an incoming and outgoing arrow between two states. But it has only one outgoing arrow between two state. ?
2. Secondly, I do not understand that the time that I have shows in AM and PM, if I want to write it in code, then what will I have to write in condition for state?
I would write code, as in the following example:
C:
enum DailyRoutine {State1, State2, State3, State4, State5, State6, State7, State8, State9} StateFlag;
int main(void)
    StateFlag = State1;
    while(1)
        switch ( StateFlag)
            case State1 :
                // I wake UP at 6.00 AM morning
            case State2 :
                // I have break fast
            case State3 :
                // I go to college
            case State4 :
                // I have lunch
            case State5 :
                // I go to Home
            case State6 :
                // I Play Games
            case State7 :
                // I do my homework
            case State8 :
                // I have dinner
            case State9 :
                // I go to bed
    return (0);
Timer interrupts can also be used for non-blocking code but will be discussed later
ericgibbs
Joined Jan 29, 2010
21,562
hi P,
What IF your phone rings or someone knocks on your door, while you are running your daily routine.?
For the Time, the 24 hour clock format works well.
E
Pushkar1
Joined Apr 5, 2021
416
hi P,
If I'm doing some work and suddenly I get a call, I'll leave work and attend the phone call first.
If I'm doing some work and suddenly someone rings my doorbell, I'll leave my work and I'll go to open the door
ericgibbs
Joined Jan 29, 2010
21,562
Morning P,
So how would you classify that phone/door activity.?
Ref your Code, how do you change State for the activity in the Switch Case.?
E
click_here
Joined Sep 22, 2020
548
"Go to college"
Surely this could be broken into different states.
You need to put "events" in.
Events are the reason you go from one states to another.
State1 - At home
Event1 - Clock was >= 9am
State2 - Walk to car
Event2 - Arrived at car
State3 - Located outside car
You could break this down to painfully small states, but you need to decide what is not a state and what is an event - Is walking to the car a state, or is it the "event" that gets you to the next state?
Pushkar1
Joined Apr 5, 2021
416
Morning P,
This code show how state change from one state to other. When I enter into any state I get activity in state
C:
#include <stdio.h>
int main()
    enum Routine { State1, State2, State3 }StateFlag;
    printf("state number : (0. State1, 1. State2, 2. State3, wrong input):");
    scanf("%d", &StateFlag);
    switch (StateFlag)
    case State1:
        printf("I wake Up");
        break;
    case State2:
        printf("I eat break fast");
        break;
    case State3:
        printf("I go to college");
        break;
    default:
        printf("Something went wrong ");
   return 0;
Irving
Joined Jan 30, 2016
5,195
Agreed, UML is heavyweight, but as a discipline to guide in the technique it works. As you suggest a limited subset serves 90% of whats needed and the more esoteric stuff can be learnt/used when necessary.
click_here
Joined Sep 22, 2020
548
C:
#include <stdio.h>
int main()
    switch (StateFlag)
    case State1:
        break;
    case State2:
        break;
    case State3:
        break;
    default:
   return 0;
Your code should change the states, not input from the user.
I'm guessing that the names "StateN" are just for these examples, but make sure that the states have more descriptive names.
Looking at my example from an earlier, you'd want it to behave more like this...
Code:
    while(1)
        switch (SystemState)
            case WaitForButton:
                if(isButtonPressed())
                    SystemState = WaitForDebounce;
                    debounceCount = 0;
                break;
            case WaitForDebounce:
                debounceCount++;
                if(debounceCount == THRESHOLD)
                        SystemState = WaitForRelease;
                    else
                        SystemState = WaitForButton;
                break;
            case WaitForRelease:
                if(!isButtonPressed())
                break;
            default:
Note how each state has an "event" that causes the state to change
Irving
Joined Jan 30, 2016
5,195
Here's another (nearly complete) example. The state diagram was drawn (badly by me) using Visual Paradigm (community edition) (good package if you take some time to learn it properly; free download, register for free educational use).
Pedestrian Crossing:
enum {
  OFF,
  ON,
  FLASH
enum States {
    Green,
    GreenWait,
    Yellow,
    Red,
    RedEnding,
    RedFinal,
    RedYellow
States state = Green; //initial state
uint8_t time_in_state = 0;
void loop() {
    switch(state) {
        case Green: {
            redMan(ON);
            beeper(OFF);
            greenMan(OFF);
            wait_sign(OFF);
            greenLight(ON);
            redLight(OFF);
            yellowLight(OFF);
            if(button_pressed){
                state = GreenWait;
            break;
        }// end Green
        case GreenWait: {
            wait_sign(ON);
            if(detect_gap_in_traffic) {
              state = Yellow;
              time_in_state = 0;
            break;
        }// end Green_wait
        case Yellow: {
            greenLight(OFF);
            yellowLight(ON);
            time_in_state++;
            if(time_in_state == 5) {
                state = Red;
                time_in_state = 0;
            break;
        }// end Yellow
        case Red: {
            yellowLight(OFF);
            redLight(ON);
            wait_sign(OFF);
            redMan(OFF);
            greenMan(ON);
            beeper(ON);
            time_in_state++;
            if(time_in_state == 20) {
                state = RedEnding;
                time_in_state = 0;
            break;
        }// end Red
        case RedEnding:{
            greenMan(FLASH);
            time_in_state++;
            if(time_in_state == 10) {
                state = RedFinal;
                time_in_state = 0;
            break;
        }//end RedEnding
        case RedFinal:{
            greenMan(OFF);
            redMan(ON);
            beeper(OFF);
            time_in_state++;
                state = RedYellow;
                time_in_state = 0;
            break;
        }// end RedFinal
        case RedYellow:{
            yellowLight(ON);
            time_in_state++;
                state = Green;
                time_in_state = 0;
            break;
        }// end Red-Yellow
    }// end switch
    delay(1000); // bad but simple...
}// end loop
