arduino iot opla, home automation, cant connect error message
  • Thread starter Deleted member 750607
  • Start date
Joined Dec 31, 1969
im trying to use the arduino OPLA IOT kit for home automation. the first project is to light up and control the color of the built in LEDs on the circular connector board.
so my code uploads to my arduino wifi mkr 1010... but when i run the program, the serial monitor shows this message:
Connection to "please work" failed
Retrying in "500" milliseconds
(i named it "please work" after a few failed attempts)
dont understand, have been trying to figure this out myself...i just want the lights to turn on, and for the "dashboard" to control the color, blink speed, etc
djsfantasi
Joined Apr 11, 2010
9,237
It would be very helpful, one might say necessary, to see your code! Click on the ellipsis icon and then select Code. You paste your code in between the tags.
Joined Dec 31, 1969
***SO this is the sample code i coped and pasted from the project's own personal page on the arduino site/iot cloud****
#include "thingProperties.h"
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
void setup() {
// Initialize serial and wait for port to open:
Serial.begin(9600);
while (!Serial);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
//Get Cloud Info/errors , 0 (only errors) up to 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
//Wait to get cloud connection to init the carrier
while (ArduinoCloud.connected() != 1) {
ArduinoCloud.update();
delay(500);
delay(500);
CARRIER_CASE = false;
carrier.begin();
carrier.display.setRotation(0);
void loop() {
// Your code here
uint8_t r, g, b;
control_RGB.getValue().getRGB(r, g, b);
if (circle_RGB == true) {
for (int ring = 0; ring <= 4; ring++) {
carrier.leds.setPixelColor(ring, g, r, b);
carrier.leds.show();
delay(100);
carrier.leds.clear();
} else {
lightsOff();
if (blink_RGB == true) {
lightsOn();
delay(blink_speed);
lightsOff();
delay(blink_speed);
if (switch_RGB == true) {
lightsOn();
} else {
lightsOff();
if (relay_1 == true) {
carrier.Relay1.open();
} else {
carrier.Relay1.close();
if (relay_2 == true) {
carrier.Relay2.open();
} else {
carrier.Relay2.close();
delay(100);
void lightsOn() {
uint8_t r, g, b;
carrier.leds.setPixelColor(0, g, r, b);
carrier.leds.setPixelColor(1, g, r, b);
carrier.leds.setPixelColor(2, g, r, b);
carrier.leds.setPixelColor(3, g, r, b);
carrier.leds.setPixelColor(4, g, r, b);
void lightsOff() {
carrier.leds.setPixelColor(0, 0, 0, 0);
carrier.leds.setPixelColor(1, 0, 0, 0);
carrier.leds.setPixelColor(2, 0, 0, 0);
carrier.leds.setPixelColor(3, 0, 0, 0);
carrier.leds.setPixelColor(4, 0, 0, 0);
void onControlRGBChange() {
// Do something
void onBlinkRGBChange() {
// Do something
void onCircleRGBChange() {
// Do something
void onSwitchRGBChange() {
// Do something
void onRelay1Change() {
// Do something
void onRelay2Change() {
// Do something
void onBlinkSpeedChange() {
// Do something
Joined Dec 31, 1969
void setup() {
Serial.begin(9600);
while (!Serial);
initProperties();
delay(500);
delay(500);
carrier.begin();
void loop() {
// Your code here
uint8_t r, g, b;
delay(100);
} else {
lightsOff();
lightsOn();
delay(blink_speed);
lightsOff();
delay(blink_speed);
lightsOn();
} else {
lightsOff();
} else {
} else {
delay(100);
void lightsOn() {
uint8_t r, g, b;
void lightsOff() {
// Do something
// Do something
// Do something
// Do something
// Do something
// Do something
// Do something
djsfantasi
Joined Apr 11, 2010
9,237
AND, I’m such a pain... Can you post a link to the project page. I see something suspicious about this sketch and would like to check it.
Also, when you post code, put it between code tags. Like this
[ CODE]put your code here[/CODE]​
djsfantasi
Joined Apr 11, 2010
9,237
Start at the beginning...
Have you confirmed that the Arduino MKR WiFi 1010 is working correctly before trying this sketch? Are all libraries successfully updated and you have the correct core loaded in the IDE? Have you run the Blink sketch?
Joined Dec 31, 1969
blink does not work either, code uploads fine, but nothing happens...maybe broken hardware?
djsfantasi
Joined Apr 11, 2010
9,237
Not that I don’t believe you, but how do you know that Blink uploaded fine? In the IDE, set preferences for verbose output. Re-load Blink, and post the compile/upload output to the forum.
Back to the beginning as I said before...
Joined Dec 31, 1969
IS THIS WHAT YOU MEAN??
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:samd:mkrwifi1010 -build-cache /tmp -build-path /tmp/795869129/build -verbose -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.esptool.path=/home/builder/.arduino15/packages/esp8266/tools/esptool/2.5.0-3-20ed2b9 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino2 -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.mkspiffs.path=/home/builder/.arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.xtensa-lx106-elf-gcc.path=/home/builder/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -libraries /tmp/795869129/custom -libraries /tmp/795869129/pinned /tmp/795869129/Blink
Using board 'mkrwifi1010' from platform in folder: /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9
Using core 'arduino' from platform in folder: /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9
Detecting libraries used...
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10611 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC -I/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/variants/mkrwifi1010 /tmp/795869129/build/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10611 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC -I/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/variants/mkrwifi1010 /tmp/795869129/build/sketch/Blink.ino.cpp -o /tmp/795869129/build/preproc/ctags_target_for_gcc_minus_e.cpp
/home/builder/opt/arduino-builder/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/795869129/build/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10611 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC -I/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/variants/mkrwifi1010 /tmp/795869129/build/sketch/Blink.ino.cpp -o /tmp/795869129/build/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10611 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC -I/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/variants/mkrwifi1010 /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/variants/mkrwifi1010/variant.cpp -o /tmp/795869129/build/core/variant.cpp.o
Using precompiled core: /tmp/core/core_arduino_samd_mkrwifi1010_7a9d71449ffb72bbc6f41d7eadc8c898.a
Linking everything together...
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -L/tmp/795869129/build -Os -Wl,--gc-sections -save-temps -T/home/builder/.arduino15/packages/arduino/hardware/samd/1.8.9/variants/mkrwifi1010/linker_scripts/gcc/flash_with_bootloader.ld -Wl,-Map,/tmp/795869129/build/Blink.ino.map --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o /tmp/795869129/build/Blink.ino.elf /tmp/795869129/build/sketch/Blink.ino.cpp.o /tmp/795869129/build/core/variant.cpp.o -Wl,--start-group -L/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Lib/GCC/ -larm_cortexM0l_math -lm /tmp/795869129/build/../../core/core_arduino_samd_mkrwifi1010_7a9d71449ffb72bbc6f41d7eadc8c898.a -Wl,--end-group
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary /tmp/795869129/build/Blink.ino.elf /tmp/795869129/build/Blink.ino.bin
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /tmp/795869129/build/Blink.ino.elf /tmp/795869129/build/Blink.ino.hex
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /tmp/795869129/build/Blink.ino.elf
Sketch uses 12284 bytes (4%) of program storage space. Maximum is 262144 bytes.
Global variables use 2952 bytes (9%) of dynamic memory, leaving 29816 bytes for local variables. Maximum is 32768 bytes.
Upload started
Programming with: Serial
Restarting in bootloader mode
Get port list before reset
[/dev/cu.Bluetooth-Incoming-Port /dev/cu.usbmodem14101 /dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem14101]
Touching port /dev/cu.usbmodem14101 at 1200bps
Set DTR off
Wait for the port to disappear
[/dev/cu.Bluetooth-Incoming-Port /dev/cu.usbmodem14101 /dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem14101] -> [/dev/cu.Bluetooth-Incoming-Port /dev/cu.usbmodem14101 /dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem14101]
[/dev/cu.Bluetooth-Incoming-Port /dev/cu.usbmodem14101 /dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem14101] -> [/dev/cu.Bluetooth-Incoming-Port /dev/tty.Bluetooth-Incoming-Port]
Wait for the port to reappear
[/dev/cu.Bluetooth-Incoming-Port /dev/tty.Bluetooth-Incoming-Port] -> [/dev/cu.Bluetooth-Incoming-Port /dev/tty.Bluetooth-Incoming-Port]
[/dev/cu.Bluetooth-Incoming-Port /dev/tty.Bluetooth-Incoming-Port] -> [/dev/cu.Bluetooth-Incoming-Port /dev/cu.usbmodem14101 /dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem14101]
Found upload port: /dev/cu.usbmodem14101
Flashing with command:/Users/hill/.arduino-create/arduino/bossac/1.7.0-arduino3/bossac -i -d --port=cu.usbmodem14101 -U true -i -e -w -v /var/folders/n5/z2gx7xvj2x140_3rshcsmct00000gn/T/arduino-create-agent139871132/Blink.bin -R
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.830 seconds
Write 12284 bytes to flash (192 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[========== ] 33% (64/192 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[==================== ] 66% (128/192 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
[==============================] 100% (192/192 pages)
done in 0.083 seconds
Verify 12284 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = 56c1
checksumBuffer(start_addr=0x3000, size=0x1000) = e065
checksumBuffer(start_addr=0x4000, size=0xffc) = 9927
Verify successful
done in 0.012 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
djsfantasi
Joined Apr 11, 2010
9,237
Exactly! Thanks.
Ok, it does look a if the load was successful. So perhaps it is hardware. Do you have another unit?
Not being familiar with the MKR WiFi MCU, I’m at a standstill. There are questions I have. Why does the loader connect at both 1200 bps and 19.2 kbps? What are the locked segments? It looks like entire memory may be locked (at 64 bytes/page, 248k is near 16 pages). And does the module have a boot loader programmed (it looks like it does).
And you are sure that the correct Arduino core module and libraries have been loaded? Again I would have expected evidence that they were not, but none is shown in the output you’ve graciously provided.
At this point, try another module, updated, or find someone familiar with that particular board. Sorry my efforts were unsuccessful.
Joined Dec 31, 1969
Exactly! Thanks.
thanks so much! i had no idea where to begin!
this is very helpful. im going to request a replacement board for the kit i got. looks like the arduino web site says one can request a replacement for a defective board.
thanks again, a huge help!!!
