Arduino Due R3 - I broke a component and I want to figure out if I can fix it
CVMichael
Joined Aug 3, 2007
421
I broke a component on my Arduino while trying to hold a nut with pliers ( because a key does not fit in there! ).
I circled it in red in the attachment. It looks like a component that is right after the power jack. It looks like a capacitor or resistor, not sure.
MrSoftware
Joined Oct 29, 2013
2,273
Ferrite bead would be for noise suppression, there's likely no harm in shorting it, but no guarantee it will work. I would give it a try. That one is only 30 ohm at 100MHz, at DC it's 25 mOhm (mili).
27,367
If you have a small ferrite bead, non-surface mount type, and if you have some fairly decent soldering ability, you can build a nonsurface mount ferrite bead and solder it on above the board in the same area. It might even block noise better.
